Class I items will need to be tested for earth continuity at whatever the BS EN standard for table lamps requires, usually 25A.Class I is not a problem but class II is, simply as they will not have been type tested, so will not have the class II stickers on them.
It's a table lamp. Can you really see an EMC problem? Take an example a wine bottle in wicker basket with an adaptor on top to take a bulb holder which already has a class II sticker on it with twin flex hidden behind the basket work then really not a problem. However using a copper or steel as the stand then completely different. I have had metal adjustable lamps cheap imports which have no class II sticker so I have failed. Not home made but no declared conformity.Class I items will need to be tested for earth continuity at whatever the BS EN standard for table lamps requires, usually 25A.Class I is not a problem but class II is, simply as they will not have been type tested, so will not have the class II stickers on them.
Don't forget these items also need to be declared in conformity with the Low Voltage Directive and the EMC Directive.
No I can't, unless of course it includes an electronic circuit such as a dimmer or LED driver. That's not the point though - it falls within the scope of the Directive, so it must be declared as being in conformity with the Directive.It's a table lamp. Can you really see an EMC problem?
Are you saying to PAT test we must test the rejection and emissions of the item under test? To my mind that's beyond the remit of PAT testing.No I can't, unless of course it includes an electronic circuit such as a dimmer or LED driver. That's not the point though - it falls within the scope of the Directive, so it must be declared as being in conformity with the Directive.It's a table lamp. Can you really see an EMC problem?
As has already been asked:... but the directive applies and therefore the person placing the lamps on the market must make the declaration.
Are lamps for use in shop or for sale?
I seeJohn (both of you) it does not matter if the lamps are for sale or not, using them in the shop is still considered "placing on the market". You might not think that logical, but it's what the law says.
