Block of 3 flats, one gf shop.
All fed via 15mm copper, have replaced all plumbing and now running 22mm throughout, to within 2 feet of underground mains water supply, to which a temporary connection has been made (new 22 to the old 15mm stub remaining)
The mains supply, type of pipe indeterminate as can not view, is terminated in a plastic connector / reducer of sorts, which is fairly large (an easy 40mm OD or more). Indicates that up to that point, the pipe must be reasonably substantial, certainly more than 15mm.
So now I have presumably 22+ mains supply, reduced to 15mm for a couple of feet, and back up to the new 22mm pipework.
Question is, how do I connect the 22mm direct to this connector, to eliminate the 15mm, and also should I be doing this or should Thames Water? Water will need closing from the street stopcock.
Thanks...
Thanks...
