2Gang 2Way Lighting Help
19 Mar 2014
Glasgow
Hi
I am in the middle of adding wall lights to my living room but have came across a problem if someone could help out please.
I have a 2Gang 2Way switch at both ends of my living room and am looking to have a switch at each end one to control the wall lights and the other to control the main lights i the living room.
The original set up was 1Gang 2Way with 2core+E to one switch with 3 Core+E going between the 2.
I have now changed it and took a neutral feed from the ceiling rose to the wall lights with the live switch wire going to the light switch and was planing on bridging the main live between the 2 Gangs. I have then ran 3 Core+E to the switch at the other end of the living room. But my problem is when i switch on the ceiling light they work fine with both switch at each end of the living room but the wall light don't come on but if i switch the ceiling lights off the wall lights come on and i can switch them on and off from each end of the living room but can't get the 2 sets of light working at the same time. the wall light will only work if the ceiling ones are off.
Any help on this would be greatly appreciated
Thanks Graeme
My first assumption is you have picked the ceiling switched live rather than the neutral
sounds to me like you have fed the switch for the wall lights via the wrong terminal of the other switch.
The original switch will have the permanent feed in either L1 or L2 not common.
You can only take the feed from the original switch that had the 2core & e and the 3 core.
You can still obtain a permanent live feed from the other switch at the other end of the room, since the perm live from the 2 core is maintained via a strapper wire from the 3 core.
Hi thanks to everyone for there time and replies very kind.
To answer a few questions asked here goes.
EFLImpudence - Yes wall lights work when both ceiling light are switched to the off position.
SUNRAY - I have re checked and neutral is defo wired correctly
One thing i am now noticing is that when i was checking wiring was correct for SUNRAY i was checking with my meter and had 244v across neutral and live with lights off when i switch light on i have 244v across neutral and live switch wire but not across neutral and live i was lead to believe the live should be constant at the ceiling rose would i be correct in saying this, As this would explain my problem if the live is going dead when light are switched on.
Cheers again Guys
I meant both off positions.
I.e. when off, flip both switches so it is off again.
You should.
Should be the same.
Bit confused.
Test Live to earth.
If you have 240V on Live and Neutral (to Earth) it will read 0V L - N.
A very detailed description or photos of the switch wiring would really be helpful here, we caould then tell you exactly what the problem is.
HI EFLImpudence
Thanks again for the response here is my answer hope you can help from the results.
With ceiling lights in both off positions wall light work
with ceiling light off at the ceiling rose i get the following results
between N and L = 244v
between E and L = 244v
between N and SL = 0v
between E and SL = 0v
(SL) = switch live wire
with ceiling lights on at the ceiling rose i get the following results
between N and L = 0v
between N and SL = 244v
Thanks Again
Graeme
Hi sparkwright
Whats the best way to attach photos and i will galdly attach them for all to see with description.
Hi sparkwright
Don't ask me!
I'm sure some bright young thing will tell you how.
Hi sparkwright
Don't ask me!
Hi Sparkwright
Please find attached photos for you 1st one is the back of the switch with live feed coming in you will see i have bridged across to other side with brown wire the red wire here is the live.
http://media.diynot.com/217000_216565_74916_49008846_thumb.jpg
Next photo is the back of the other switch with the 3 core + E wires
Hope these help
Cheers
links to photos above on the 1st link the right hand side is the ceiling light with live feed and left hand side is the wires for the wall lights
