Hi
I am in the middle of adding wall lights to my living room but have came across a problem if someone could help out please.
I have a 2Gang 2Way switch at both ends of my living room and am looking to have a switch at each end one to control the wall lights and the other to control the main lights i the living room.
The original set up was 1Gang 2Way with 2core+E to one switch with 3 Core+E going between the 2.
I have now changed it and took a neutral feed from the ceiling rose to the wall lights with the live switch wire going to the light switch and was planing on bridging the main live between the 2 Gangs. I have then ran 3 Core+E to the switch at the other end of the living room. But my problem is when i switch on the ceiling light they work fine with both switch at each end of the living room but the wall light don't come on but if i switch the ceiling lights off the wall lights come on and i can switch them on and off from each end of the living room but can't get the 2 sets of light working at the same time. the wall light will only work if the ceiling ones are off.
Any help on this would be greatly appreciated
Thanks Graeme
Thanks Graeme
