My parents have a downstairs room with a fireplace that smokes. The house was built in the mid 1980's and has an external chimney stack with clay liner. Originally the builders installed a baxi underdraft grate, but this smoked into the room from new and was soon abandoned for an electric insert.
In these chastened times, they have decided to try and press the fireplace back into use and have had a recessed log-burning stove installed professionally. The chimney was swept and the installer fitted a new chimney pot.
The problem is that it STILL smokes. Once the fire is lit and the door closed, streams of white smoke literally billow out of every orifice of the stove (damper handles, door catch, hinges). It's stunk the house out, so a £700 stove is sitting there useless.
I have recommended a variable speed power flue fan to improve the pull; another expert has said these are rubbish and what they need is a stainless steel flue liner which will cure all their woes.
Any advice on what to do?
