I have a couple of long glass hanging lights in the Kitchen over the breakfast bar, which were fitted a couple of years ago when the house was built.
One of the lamps dropped several inches and when I investigated I found that the weight of the lamp was help by a clear plastic friction nut which screws into the metal ceiling rose that is then held by 2 screws onto a plate fixed to the ceiling. However the plastic cable clamp has cracked and is no longer holding the cable which then slipped down and all the weight was being held by the cables screwed into the the connector strip from the ceiling.
This seems like a very poor design (although the light cost several hundred pounds).
Trouble is I don't know what I need to buy to repair it but I think I need some sort of cable clamp that can go inside the metal rose so that the wight is held by the metal rose and ceiling plate rather than just on a weak brittle cable clamp.
Grateful for some advice on what I need and what its called.
For now I have disconnected the fitting completely by removing the fitting wires from the connector block on the ceiling.
