I really think you must have somehow brought the neutral into contact with earth.Interesting, John. I certainly recall working in a house where when I touched the neutral it tripped the RCD - without having moved any wiring or anything, so I'm pretty sure I wasn't bridging it to earth except through me. It sticks in my mind because having reset the RCD I stupidly did exactly the same a second time!
Unless there was some major fault somewhere in the installation, the neutral would be pretty close to earth potential - not remotely high enough to send 30mA through you. In any event, as I said, if 30mA did go through any part of you, you would 'feel' that as a very severe shock.It hadn't occurred to me that I should have felt a shock. Possibly with it being the neutral the potential may have only barely been high enough to cause 30mA through my forearm ...
I presume you're not serious. That would obviously be very silly and, because RCDs are definitely not a foolproof panacea, it could be the last thing you ever did.EDIT: I'm almost tempted to try touching a live just to compare, but that way lies 'asking for it', so instead I'll just try to take special note if/when I trip anything again by accident.
