Hi, I am trying to replace an old electric shower pull cord switch (first Pic). I purchased a new switch and the terminals are not in the same position. Old switch both N are on the left side and L on right side. The new switch has the N on the bottom and L on the top (second Pic). I basically turned the new switch when wiring 90 degrees to match old wiring. When I turned on the mains the shower just automatically runs (before it didn't start until you press the button on the actual shower).
So, I swapped over the two N wires to see if that made a difference which is didn't (The shower still ran automatically). I swapped the wires back and tried reversing the L but still same problem?
I cannot figure out what the problem is as I think I have tried every combination? Any advice please?
