- Joined
- 7 Oct 2012
- Messages
- 41
- Reaction score
- 1
- Country
Hi guys. I've some questions about how my house is wired. Built mid 80s. Terraced on an estate.
I just want to be sure it's safe. My terminology is probably poor and I don't know what all the acronyms mean always. But I will do my best to describe.
Most houses I have come across have the ability to cut off power at the consumer unit to for example all upstairs sockets, all downstairs, oven etc. My house is not wired like that. The consumer unit has from left to right:
32A breaker 1
16A breaker 2
32A breaker 3
80A RCD
Blank spare slot
6A upstairs lighting circuit
6A downstairs lighting circuit
32A upstairs electric shower
100A main switch
The first 3 breakers do sockets around the house but some sockets up and down are attached to each. In fact each one does this:
32A breaker 1 =
Kitchen sockets (but not the Hob lighter or oven)
Cooker hood extractor
hall sockets
Bedroom 1 all sockets
Landing socket
16A breaker 2 =
Lounge all sockets
Hall cupboard socket (spur from lounge socket)
1 x Kitchen socket in corner (spur from lounge socket)
Bedroom 3 all sockets
Bedroom 4 all sockets
Conservatory sockets (x5 double)
32A breaker 3 =
Cooker main oven
Cooker hob lighter
1: Is the above ok to have a house wired like that?
2: I'm also wondering why there is only a 16A breaker on the number 2 breaker, which actually does by far the most sockets. It has the entire lounge (hifi area, tv, consoles, pc) and 2 bedrooms, the fridge/freezer from the corner socket in kitchen spur, and 5 x sockets in the conservatory.
Can/should I replace this for a 32A one? I don't and have not had ANY problems with tripping.
The conservatory 5 x double sockets have been put in by someone spurring off one of the lounge sockets (ring main I think you call it?) and then out through a wall to the outside, under some decking for a few feet and then back into the conservatory through the wall. This cabling is twin and earth which measures 9.9mm x 5.5mm. It is white in colour.
At the end of the run of 5 sockets in conservatory from this spur, it finishes on what I think you call a switched fuse box. i.e. Just a big switch you can turn on or off. From this switch an SWA cable starts and goes out the conservatory wall, under ground and out to the garage giving power there. The SWA cable says on it BS5467 ELECTRIC CABLE 600/1000V BASEC Cu/XLPE 4x2.5mm 1998.
At the garage the SWA enters and goes straight into a single socket with switch and then continues out of this to another switch box which powers a tube light. There is no consumer unit or anything in the garage or conservatory. Only in the downstairs toilet is the main consumer unit.
3: I want to know if I am correct in thinking the garage is now limited to 13A from the switched fuse in conservatory.
4: If yes, can I increase this limit to 16A or 32A by taking the switched fuse out and putting a proper small consumer unit at the garage to have a proper separated lighting and socket circuit.
It is extremely difficult to wire the garage direct to the consumer unit without major operations on the house which I cannot do. (I do not own the house) but can do minor to medium stuff.
Thanks all.
32A breaker 1
16A breaker 2
32A breaker 3
80A RCD
Blank spare slot
100A main switch
32A breaker 1 =
hall sockets
Landing socket
16A breaker 2 =
Lounge all sockets
32A breaker 3 =
Cooker main oven
Cooker hob lighter
Thanks all.
