Here you go then. Doing a mains upgrade at a site (some twit installed around 50kW of heating onto an already well loaded SP 18kW supply!). Same chap added a new light in the cupboard with the fuse boards in. I get the reasoning.......but really?
Yep. It bugs me when people go in and swap out fuse boards for dual splits, with no consideration. In commercial installs you do not want everything on RCDs.
Some lifts in smaller commecrial buildings only require a 16A SP supply these days, generally only go up one or two floors and don't generally have a lift motor room, normally just a small hydrallic unit about 1m tall and 600-800m wide.
Generally go in buildings which would in years gone by would have never had a lift, but need to these days for disabled access
