    Dismiss Notice
Going through some recent-ish photos...
Discussion in 'Electrics UK' started by Lectrician, 22 Jul 2014.
  1. Lectrician
    Lectrician
    18 Jul 2004
    8,470
    Thanks Received:
    399
    Devon
    Country:
    Here you go then. Doing a mains upgrade at a site (some twit installed around 50kW of heating onto an already well loaded SP 18kW supply!). Same chap added a new light in the cupboard with the fuse boards in. I get the reasoning.......but really?
    [​IMG]
    [​IMG]
  2. Sponsored Links
  3. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,197
    Thanks Received:
    2,086
    Oxfordshire
    Country:
    :eek:
    So he could afford a couple of cable ties (to make it look neat) but not some earth sleeving.
    :eek:
    ANd does the line conductor from that bit of 1mm really just go in to the base of the MCB? :eek: :eek:
  4. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,858
    London
    Country:
    Looks like it.
    Tell me that it doesn't say "Lift" on the 3rd MCB... :eek:
  5. Lectrician
    Lectrician
    18 Jul 2004
    8,470
    Thanks Received:
    399
    Devon
    Country:
    Yep. It bugs me when people go in and swap out fuse boards for dual splits, with no consideration. In commercial installs you do not want everything on RCDs.
  6. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,858
    London
    Country:
    So it does say Lift?
    That is a commercial installation?
    And therefore the "electrician" (and possibly the employer) have broken the law?
  7. Sponsored Links
  8. Spark123
    Spark123
    2 Jun 2005
    14,841
    Thanks Received:
    474
    Cumbria
    Country:
    It looks a bit small to be supplying a lift that you walk into, maybe just a stair lift?
  9. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,858
    London
    Country:
    Could be.
    Or a vehicle lift?
  10. bernardgreen
    bernardgreen
    3 Nov 2006
    25,020
    Thanks Received:
    2,471
    Bedfordshire
    Country:
    With two wires it might be the ring final to the loft. ?
  11. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,197
    Thanks Received:
    2,086
    Oxfordshire
    Country:
    Think it says B16. Probably the immersion with another radial to the "lift"
  12. Adam_151
    Adam_151
    17 Jun 2004
    6,653
    Thanks Received:
    270
    Country:
    Some lifts in smaller commecrial buildings only require a 16A SP supply these days, generally only go up one or two floors and don't generally have a lift motor room, normally just a small hydrallic unit about 1m tall and 600-800m wide.
    Generally go in buildings which would in years gone by would have never had a lift, but need to these days for disabled access
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
