Hi All.
I have recently bought a 25 year old bungalow in a Shaugh Prior in Devon.
The bungalow hasn't been touched since it was built so everything is original. Including the lovely Fan effect artexing on the ceilings. I have been slowly removing all of the ceiling lights and putting up ceiling roses in readiness for the plasterer that's coming on Friday.
What I found when I removed the lights was the 3 cables (switch cable, loop cable & live cable) were all wired into a ceiling rose and then the flex from the ceiling rose was used to wire into the lights, the ceiling rose was then stuffed into the celing so the drop cable was visible.
I have now removed the old ceiling roses and wired them into new ones and attached the new ones to the ceiling.
My question today is: would it be better to wire the 3 cables (mentioned above) into a 4 terminal junction box and drop a drop cable down into the room to attach the ceiling rose to instead of the 3 cables coming through the ceiling in each room?
I am only thinking that it would give a better finish to the plastering and would be easier to fit our chosen lights to when we decorate each room.
Sorry if I have used the wrong terminology for any of the cable names above, I am a very competent DIY'er but not a professional.
Thanks in advance
Mark
Thanks in advance
Mark
