If one looks pretty hard, there are a few 2-gang switched trailing sockets out there (well,at least in Hong Kong - goodness knows if one could find one), but I've yet to see any single gang ones with switches:If you want the swith at the socket end then things are a bit tricker, you could go crystal ball's approach of using a socket intended for permanent installtion with a gland but that leaves you with a rather bulky and potentially fragile (depending on exactly what sort of surface mount socket you use) end.
Yes but switching this off will turned off the TV.Does the socket on the wall not have a switch?
I don't really understand that. Can you possibly explain in more detail? What is plugged into what, and where is the TV timer (and why does the TV have a timer?). What do you want the extension for - the raspberry pi?Yes but switching this off will turned off the TV. ... What I have got is a raspberry pi and link up to the television and when the electricians switch the mains off or power cut then the electric is on again the television switched on but the raspberry pi will need to be reboot while the television is still on. The television is on a timerDoes the socket on the wall not have a switch?
Sorry this was confusing, will take some photo's tomorrowI don't really understand that. Can you possibly explain in more detail? What is plugged into what, and where is the TV timer (and why does the TV have a timer?). What do you want the extension for - the raspberry pi?Yes but switching this off will turned off the TV. ... What I have got is a raspberry pi and link up to the television and when the electricians switch the mains off or power cut then the electric is on again the television switched on but the raspberry pi will need to be reboot while the television is still on. The television is on a timerDoes the socket on the wall not have a switch?
Kind REgards, John
Many thanks - I look forward to seeing them (although probably not until Thursday - I will probably not be around tomorrow!).Sorry this was confusing, will take some photo's tomorrowI don't really understand that. Can you possibly explain in more detail? What is plugged into what, and where is the TV timer (and why does the TV have a timer?). What do you want the extension for - the raspberry pi?
Well found! As you say, it might well satisfy the OP's requirement. I searched for 1-gang and 2-gang individually switched trailing sockets/extension leads but, because I was not thinking of 'block sockets' did not bother with 3-gang or above!Ooh, look what I found…. Masterplug do an extension leand that finishes in a three way block socket. Each of the outputs is individually switched. ... Normally I don't like those three way socket adapter thingies when plugged into the wall, but this may suit the OP's situation??
Did you get permission to take a day off?Many thanks - I look forward to seeing them (although probably not until Thursday - I will probably not be around tomorrow!).
I've never seen an inline 13A+ rated switch
