Small extension lead with built-in switch?
5 Jan 2003
Essex
I want to make a small extension lead but would like to have a switch without having to pull the plug out on the socket side, are they available?
13 amp plugs with integral switches are available, as are 4 way extensions with switches, but if you want a single socket extension why not use a switched socket on a surface box with 20mm knockouts, use a stuffing gland to grip the flex
Where exactly do you want the switch?
If you want it at the plug end then you can get switched plugs. e.g.
http://cpc.farnell.com/pro-elec/2138/plugtop-switched/dp/PL1003707?Ntt=PL1003707
If you want the switch in-line then you can get in-line switches the highest current rating i've seen is 6A. Whether that is a problem depends on what you plan to use the lead for.
http://www.amazon.co.uk/Skytronic-429-376UK-Inline-Switch-White/dp/B000NVRCHK
If you want the swith at the socket end then things are a bit tricker, you could go crystal ball's approach of using a socket intended for permanent installtion with a gland but that leaves you with a rather bulky and potentially fragile (depending on exactly what sort of surface mount socket you use) end.
If you are always using it with the same appliance you could take the plug off the appliance and either use an inline switch or a switched plug.
If one looks pretty hard, there are a few 2-gang switched trailing sockets out there (well,at least in Hong Kong - goodness knows if one could find one), but I've yet to see any single gang ones with switches:
Kind Regards, John
What about a remote controlled socket, or strip?
Or - I've never seen an inline 13A+ rated switch (apart from some alleged ones on Amazon which could well kill you), but I have seen lots of inline RCDs, so if you don't mind a bulky solution....
Does the socket on the wall not have a switch?
Yes but switching this off will turned off the TV.
What I have got is a raspberry pi and link up to the television and when the electricians switch the mains off or power cut then the electric is on again the television switched on but the raspberry pi will need to be reboot while the television is still on. The television is on a timer
Yes but switching this off will turned off the TV. ... What I have got is a raspberry pi and link up to the television and when the electricians switch the mains off or power cut then the electric is on again the television switched on but the raspberry pi will need to be reboot while the television is still on. The television is on a timer
I don't really understand that. Can you possibly explain in more detail? What is plugged into what, and where is the TV timer (and why does the TV have a timer?). What do you want the extension for - the raspberry pi?
Kind REgards, John
Kind REgards, John
Sorry this was confusing, will take some photo's tomorrow
Many thanks - I look forward to seeing them (although probably not until Thursday - I will probably not be around tomorrow!).
Kind Regards, John
Ooh, look what I found….
Masterplug do an extension leand that finishes in a three way block socket. Each of the outputs is individually switched.
CLICK ME
A beter picture HERE (Click the 3-way one)
Normally I don't like those three way socket adapter thingies when plugged into the wall, but this may suit the OP's situation??
Ooh, look what I found…. Masterplug do an extension leand that finishes in a three way block socket. Each of the outputs is individually switched. ... Normally I don't like those three way socket adapter thingies when plugged into the wall, but this may suit the OP's situation??
Well found! As you say, it might well satisfy the OP's requirement. I searched for 1-gang and 2-gang individually switched trailing sockets/extension leads but, because I was not thinking of 'block sockets' did not bother with 3-gang or above!
Kind Regards, John
