Hello,
Just wondering if anyone could confirm the following wiring modification would be correct.
The cct from consumer unit is the downstairs lighting circuit which currently has 1 outside light connected to it. I plan to add another light powered from the same external terminal box as in the picture, the new light and pir will be attached to external wall of house. (Of course the earth runs throughout the circuit.)
Also, would the addition of an outside light require RCD protection on the lighting circuit? (The light will be approximately 2m high from the ground and is metallic).
Thanks,
Thanks,
