Never underestimate the persistence of stupidity.Please enlighten us oh great one.
You figured out precisely squat.
Oh no. The Vokera SE is keeping me warm right now. Why would I make all this up?You're not an idiot but why would anyone want to help you? Just a troll.
OP - Could VC be correct? I'm usually quicker off the mark but the version of your story that makes more sense to me is that there is no flat, no installer, no Compact SE and the whole thing is a fabrication.
Idiot, you have contributed sweet FA to this thread so why don't you FO you know-nothing fool. I have reported you to the mods as your tactic is to wreck threads. One man on the other thread wrote that you post pictures of your installs and they are poor. All fits.Never underestimate the persistence of stupidity.Please enlighten us oh great one.
Precisely
OK I will go with that as your experience states it does not happen. I just find it hard to believe that if return pipe water enters a boiler at say 5C into the boiler and the boiler is set to minimum there will be no condensation.As I wrote any condensation forming would be whisked away in the fan stream.
It's taken all weekend but I'll try once more,
THERE IS NO CONDENSATION FORMED IN THE COMBUSTION CHAMBER OF A LOW WATER CONTENT, COPPER FINNED HEAT EXCHANGER AS FOUND IN TYPICAL SE COMBIS AND SYSTEM BOILERS.
My reasoning is that condensation does appear (it has to, physics says so) for a short period with the fan stream taking it away as it is forming. The burner box is in the fan air stream. That is why I see some non-condensing boiler flues dripping slightly on the landings of my block. In normal operation where a house or flat does not get that cold when the heating is off, and hence the temp' of the water in the radiator is not very low, and the non-condensing boiler is set high, any condensation will be minimum and whisked away immediately. I does form, it has to. It is just taken away immediately. In non-fan boilers as you mentioned, the heat of the burner box must deal with any drips. Drips would fall into very hot flame and turn to steam and out of the flue.The fan clears POC's and doesn't clear condensate even in a condensing boiler. Worcester and Vaillant once made BF models of combi without fans, they didn't condense either.
I am inquisitive, I am far from silly, as my responses show you. I am amazed at the attitude and silliness of the so-called professionals on this forum. This Dan guy is still trying the wreck threads. Why don't the mods close these people down?Not meaning to be rude but one could be forgiven for thinking you're being deliberately silly.
As one old pipe fitter said to me, "you can always tell a poor fitter as he uses elbows everywhere". Just stop now. They look like copper push-fit elbows as well, like those B&Q sell but larger bores. . No need to show us any more thank you.![]()
I couldn't agree moreAs one old pipe fitter said to me, "you can always tell a poor fitter as he uses elbows everywhere". Just stop now. They look like copper push-fit elbows as well, like those B&Q sell but larger bores. . No need to show us any more thank you.![]()
What a w*****.
You will not get one as I do not dance to the tune of the irritating fool of a jester. Run along and stop infesting threads and learn how to use a bender. You have not once contributed ANYTHING to this thread.But not a sausage from your good self.
