Hi people
I have a Vokera Compact HE combi boiler, it has been in the house about 7 years and never given us a moments trouble until now.
Starting yesterday morning when we try and get hot water from any tap the boiler sounds like its firing up fine then the light goes solid green to say its fired and the water starts to warm up then bam the light goes solid red and the water goes cold. If we leave the tap running the same cycle starts again after the red light goes out it sounds like its firing up the water starts to warm a bit then red again and cold.
Once this has happened the same seems to happen to the central heating when the roomstat calls for heat.
If I move the switch to reset for a second the central heating will fire up ok and the rads all warm up but as soon as we try the hot taps the red light cycle starts again.
I'm willing to try a little diy to save some money but understand if this means calling out a professional I will.
Any advice appreciated as plumbers in this area I have spoken to in the past don't seem very confident with Vokeras for some reason?
Regards
Jamie
Regards
Jamie
