Hi to everyone,
This is my first post, so thanks in advance for reading!
We recently moved into a new house where pretty much all the jobs have been botched badly and I'm setting about fixing them all. Next on the list is the door frames in the extension. I'm learning as I go and am pretty new to all aspects of DIY.
The previous owner used door frames that are all too wide for the walls by as much as 15-20mm both sides. They then just fitted the doors to them and attached unfinished trims with no supports for the wall overhang.
How do I go about fixing this? I can remove the trims and then take the doors off one at a time. I then need to cut back the frames to match the walls and re-hang the doors. Is this the best approach; if so what's the best tool to use for this?
Sorry for all the questions...
