Fitting a door in a crooked frame. Best strategy please?
9 Aug 2006
Lancashire
I'm about to fit a new door in a new frame. Unfortunately the hinge side of the frame is about 5mm out of vertical, going narrower at the bottom.
I will trim the door to fit. Should I then simply hang as normal or try some fancy stuff with the hinge rebates to try to get the door moving vertically?
I suppose a frame side that slopes "upwards" is worse than one sloping "downwards" from the point of view of the way the door will swing.
i am assuming the legs are parralel with each other and the wall face
is the deviation along the length!!! if so just shoot in hinge side first [as normal]
if it kicks out just at the bottom try a block off wood and sharp tap but dont overdo it incase you knockthe frame out off line
yes as normal
5 mm is such a small amount its not even worth worrying about half and half[removing 2.5 one side 2.5 other side ] just fit as normal
:D
