SWANN DVR9-1425, replacement
9 Sep 2011
Essex
Hi all,, as a family we purchased a SWANN DVR9-1425 with 4 wired bullet cameras from Maplin in Nov 2014. Since install had untold false alarms, especially over night even with sensitivity at its lowest.
System has hung on 3 or 4 time with today the latest failing completely with a boot loop making unusable.
Swann have asked for us to return back to them and they will repair or replace in 7-10 working days with us footing the initial shipping. :-( However I feel it maybe a better choice to rip out and return all components to Maplin and install better unit. Admittedly was purchased on a budget and cost £310.00 but hoping some advise may help from here.
Criteria we need is minimum 3 cameras for external and internal, remote monitoring and motion ..
Thanks,
John
Swann = rubbish.........try Hikvision at the buget end and don't expect any unit to be false alarm free using on screen motion detection, you will need quality outdoor detector for this !
Take it back to where you purchased it from and say it isn't fit for purpose and ask for a full refund.
Looking like the plan .. Just need to find the best replacement .. Just need a low maint solution .. Checking the earlier suggestion.. See how we go .. Thanks
Hikvision are now doing the turbo TVI range 1080res over standard coax plus you can mix TVI and standard cameras on the same unit .
