Sorry for the late reply everyone - I've only just got home from work - I spoke to one of my colleagues OH who is an electrician, he feels that it may be due to the minimum load (which on these dimmers is variable due to the vast difference between LEDs) is not being met
I don't have any 'normal' candle bulbs and forgot to pick one up on the way home - he suggested if that if it works then I require a Resistor to help increase the load - I've heard that for GU10 LED issues...
I read on Lightwave's compatibility notes, they don't mention Phillips anywhere so @RF Lighting may be correct in that they're not compatible, in their notes they mentioned the minimum load issue and that 2 resistors may be required
Do any of you feel that could be the case here? Minimum load not being met
I will be buying a full wattage bulb to see the outcome, I will also take up Bernard's suggestion of disconnecting the dimmer & wiring it up to a terminal block
Sheds - I will rewire to all up properly once / if I ever get the thing to work properly & yes all the earth wires connect to the light fitting via a terminal block
in regards to the red tape etc, I did this just to identify the switch cable - will get some brown tape on it once it's all resolved (wishful thinking!)
