Hi All
So I am in the process of installing built-in wardrobes and one thing I had roughly planned to do was to install lights to come on whenever a door was opened. I have ordered the lights already which are just under cabinet kitchen lights which I plan to have under each shelf but my query comes from how to wire up the switches.
At the bottom of this post...
http://www.diynot.com/forums/electr...o-break-door-switches-to-1-led-driver.316697/
...there is a helpful diagram from Lectrician so I understand how to wire up the switches to enable the lights to come on.
The wardrobes have three doors (the two end doors will be on the back rail and the middle door will be on the front rail) so I was planning on putting a push-to-break switch on either of the end doors so that when the doors are at the extreme left and right the switches will hit the wall and the circuit will be broken and no lights will come up. But I'm a bit stuck on the middle door. I can't think of a way to connect this to a switch as 1) the door will not rest against a wall 2) If I added anything to the door or ceiling to hit a switch it would likely hit one of the other doors when they were opened.
So am I missing something? There must be a way that a professional would install this kind of setup so that the lights came on when any door was opened?
Thanks in advance.
Thanks in advance.
