Wiring a switch to a socket
Thanks Chivers, I ideally want to stay away from using an FCU if possible. I don't really want and FCU on display and also don't want to take the plug off the kit in case it needs returning etc.
Do you have any other suggestions?
The plug in that kit includes the driver for the LEDS so you cannot just cut off the plug.
An FCU wonthelp you either, unless you add another socket to it.
So you are stuck with what you have got.
Turn the lights off at the socket, or buy one of those remote control sockets, then you can control the lights with a remote control thingy.
He could surely take a spur from the ring to an unfused dp switch, then on to a socket, much like is done in kitchens for the appliances?
The unfused dp switch looks just like a light switch and could be mounted beside the existing light switch.
So I could spur from the ring with 2.5mm TE to an unfused dp switch then 2.5mm TE to another socket so that I can plug the lights in yeah?
Where can I find an unfused dp switch as I can only seem to find 20amp ones?
