Loose Half Newel Post
20 Feb 2010
Norfolk
I have just moved into our new home and discovered the handrail on our walkway is loose. On investigation the timber fitted to the wall which the hand rail fixes into has movement, and as you can see from the pictures their is a gap at the bottom. From research i understand this is called a half newel post?
How do i fix this?
There is a visible screw on the side which i have tried to tighten but is already tight. When moving the newel post laterally you can feel it hitting some kind of bracket or post.
View media item 93744 View media item 93745 View media item 93746 View media item 93747 View media item 93748
might be easiest to open the wall the other side and look for timbers it should be fixed to and pilot the timber noggin and screw into the back off the newel
you may off course find there is no timber but wall anchors or similar that will be the problem
not sure if a noggin has been put in the wall. What size opening do you mean on the other side of the wall as i don't want to create more repair work than necessary.
ideally to the stud each side
cut to the side off the nail/screw head in a line so the board can be fixed back to the timber
remember unless the half newel is within 50mm of a stud you will have to fix a timber between the studs horizontally to fix the newel to
Thanks for your help. This job sounds like it's best left to a professional.
