I have just moved into our new home and discovered the handrail on our walkway is loose. On investigation the timber fitted to the wall which the hand rail fixes into has movement, and as you can see from the pictures their is a gap at the bottom. From research i understand this is called a half newel post?
How do i fix this?
There is a visible screw on the side which i have tried to tighten but is already tight. When moving the newel post laterally you can feel it hitting some kind of bracket or post.
View media item 93744 View media item 93745 View media item 93746 View media item 93747 View media item 93748
How do i fix this?
