recently had all the electrics replaced but found that where the socket has been fitted for the dishwasher its stopping it fitting under the unit correctly.
current set up is standard single gang socket underneath the worktop with a fused switch above the worktop (to be able to switch it off in an emergency if needed.
what i plan to do is either
1: move the socket thats under the cabinet 6 inches to the side behind the fridge where its not in the way (will need new cable to extend it this distance)
2: replace the socket under the counter with a 13A fused switch, cut the plug off the dishwasher cable and wire it directly in to it.
are either of the above classed as notifyable work and need a Part P electrician to modify it?
can anyone see any issues i'm not aware of with these.
thanks in advance.
thanks in advance.
