A Professional Installation...
11 Jan 2004
Open to the elements! Gland not weatherproof. Not sure if glands are suited to T+E. Not sure if T+E is best choice fot external use, especially where it could be subject to wood preaervatives.
The biggest problem here I would say is the SWA sheath has presumably been cut into to so the armour can make contact with the earth clamp.
So the armour can get wet and rust away.
All could have been avoided with a banjo or perhaps better still one of those locknuts with the screw holes in them - can't for the life of me remember what they are called...!
Don't tell him, Pike!
Moderator 8 said:
Abusive post removed. This message must NOT be reposted as you have been told time and time again.
The only post I am aware of that's been removed was mine, in which I suggested in response to sparkwright's "All could have been avoided ..." that it could also have been avoided by having the work done by someone actually able to do it.
I was unaware that suggesting that people be competent is abusive, and I am unaware of having been told time and time again that I must not repost such a suggestion.
Unless you can show where I have been told that, I cannot help but ask what is wrong with you?
You mean the Piranha Earth Locking Nuts; Well I love them!
I would say no, likely wont close round the cable properly to make it water tight.
Not sure if T+E is best choice for external use
No it's not, it is not protected from UV radiation what will degrade the cable.
Also as sparkwright said, the SWA armor has been severely impaired, letting water in what over time may corrode the armor and make it's way into the box.
Moderator 8 said:
You wrote "someone who actually had a f****** clue."
This is abusive and not an acceptable thing to post on this forum.
Shame you are so one-sided in the way you deal with posts containing *'s or similar.
Moderator 8 said:
You have been told many times not to repost things which have been removed by moderators.
I haven't reposted it.
Not at all.
Just trying to find out if "******" is not acceptable but "&~#@%?", for example, would be.
Also, I wonder if whoever it was who complained has seen the cartoon in yesterday's Metro:
If so, or when they do, I hope they will similarly complain to the publishers - after all, that paper is given away on trains, and is seen by millions of people, potentially including many children. Unless they are biased in their judgement of what is acceptable and what is not, then they really should complain.
Not at all.
I seem to remember, from personal experience I should add, that the site can tell the difference between a rude word which appears to turn into asterisks; and simply a line of actual asterisks.
So I don't know if you actually typed in a rude word or a line of asterisks.
Personally, I would (now) stick to typing actual asterisks myself, or that & Ω^@%? language.
Trouble is, it can't actually tell which are rude words; it just bans THE word.
There are some blue tits in my garden.
