That's why the good ol' reg book tables of current start at 16mm and go up to hella big
Sure, but we're talking about 4mm² cable in your kitchen ring (and, as you say the "good ol' reg book" will not help you in determining the CCC of that!)!That's why the good ol' reg book tables of current start at 16mm and go up to hella big![]()
Quite so - I suspect that (unless the cable were ginormous) most of the conductor would have to be copper before it made much difference! As I've been saying, I can but presume that the copper is/was there primarily to reduce surface corrosion.I think the copper cladding would need to be extremely thick to have any noticable impact on CCC, even taking account of skin affect.
More likely that these days aluminium is only used for large cables, where weight is a real issue.That's why the good ol' reg book tables of current start at 16mm and go up to hella big![]()
I've never even seen any type of aluminium cable - was/is most/all of it copper clad?
With ferrules, you are still crushing the wire itself when a screw is tightened onto it, so there is still the possibility of one or more strands breaking inside the ferrule.Cheers Flame, Is there a particular reason to prefer the pin crimps over ferules?
Thanks! That's clearly not copper clad/coated....This was in my parents house. ....
