External door dropped
20 Apr 2005
Gloucestershire
I had a solid oak door fitted about a year ago, since then the door has started to drop very slightly.
On inspection, the joiner has cut too much off the bottom of the door completely exposing the tenon joint, leading to the door now being more of a parallelogram.
What are my options?
Thanks for looking.
Is there any way you could take down the door from the hinges?
If so, I'd suggest bracing the exposed tenon joints with a crosspiece; it depends how much space you have to add additional wood lengths tbh.
A quick fix would involve adding the lengths, planing it level for a correct fit inside the door frame, and applying the external varnish
How can too much be cut off? Surely its been reduced to fit the opening?
I'm also not clear how this is related to it dropping?
yes i was wondering how 4 tight mortices would would let it sag assuming it had at least one middle rail
There only appears to be a top and bottom rail. Hopefully the photos will provide some clarification. Thanks for the messages so far
i dont want to criticize another man s work but it looks close to 50mm cut off the bottom :(
Yeah, I'm afraid he's taken far too much off hence the issue, can you see the top of the door and how much the wood has come away from the top rail?
You also have to take into account that the timber in the middle is loose fitting to avoid cracking.
Sorry to say but it was very poorly fitted, and unfortunately it will need replacing as even if you changed the bottom rail you would need to change the lock positions and the hinge positions. Long shot I know but Is it possible to get the guy back that fitted the door originally and see if he is prepared to help at all.
