I hope you guys can help. Whatever I do I can't get the inlet hose of my washing machine to properly attach to the inlet pipe! I have tried exceptionally hard to get it as straight as possible, but it always leaks. I have bought a brand new hose, same problem. I've tried plumbers tape, which has mostly worked. Ultimately I have a bucket under the work surface so at least it can drip into that and I can empty it periodically. It is a minute drip, but that adds up. I've not had this problem when I've plumbed in other washers. Is it possible that the inlet pipe fitting is the problem not the hose? Or is there an easier way? Some cunning devise or fitting I have no knowledge of? It's extremely frustrating - I have to drag the washer out once a month to empty the bucket.
I've looked at you tube at see if I'm missing a trick, but they are just doing exactly what I've been doing.
Any suggestions?
Any suggestions?
