Ok the hob is 6.2 kw, the cable is 6mm,the new appliance is a oven and grill to be hardwired the oven is 0.79kw and the grill 0.99kw , as for the breaker size in the fuse box they all say 230/400v
Technical specifications for BELLING BI90FP Electric Double Oven - Stainless Steel
OVERVIEW Type Built-in double oven Fuel Electric
CONTROLS Timer type Programmable Cooking functions 3 Display type LED display Control type Dials
OVENS Oven type - Top: conventional
- Bottom: fan Number of cavities 2 Size - Top: medium
- Bottom: medium Capacity - Top: 35 litres
- Bottom: 58 litres Energy rating A Energy consumption 2 kWh Viewing window - Top: double-glazed
- Bottom: double-glazed Interior light Yes Type of cleaning Easy-clean ename
Lets look at it another way. If the MCB controlling the cooker circuit is 32A or 40A AND if the cable is 6mm² then you can connect both the oven and hob to this circuit.
