It would be useful for identification.
Do you have all brown 3c+E for two-way strappers?
It must be a pain working out which conductor to connect to what.Indeed, and ...Do you have all brown 3c+E for two-way strappers?
It isn't useful for identification to have a phase conductor in any colour other than that appropriate for a phase conductor.It would be useful for identification.
It does if you want to avoid EMC.And no, there isn't 3-core brown. Two-way switching does not require 3-core cable.
Of course it is.It isn't useful for identification to have a phase conductor in any colour other than that appropriate for a phase conductor.
Why would you want to avoid Electro-Magnetic Compatibility?It does if you want to avoid EMC.And no, there isn't 3-core brown. Two-way switching does not require 3-core cable.
Whoops - slip of the brain/typing fingersWhy would you want to avoid Electro-Magnetic Compatibility?It does if you want to avoid EMC.![]()
I have to say that on the rare occasions I've come across red/red cables (I've never met a brown/brown one), I have, for my own purposes, over-sleeved the S/L with red sleeving, so as to be consistent with my convention with red/black switch feeds.
Interestring - that's two of you who have said that now. All I can say is that if the few twin reds I encountered (a long time ago) had white under one of the reds, I didn't notice it - hence my over-sleeving red with red! As I said, I've never dealt with twin brown, so can't speak for that!I have installed both twin red and twin brown which was identified by one core being that colour all the way through the insulation and the other white inside.I have to say that on the rare occasions I've come across red/red cables (I've never met a brown/brown one), I have, for my own purposes, over-sleeved the S/L with red sleeving, so as to be consistent with my convention with red/black switch feeds.
Because the only relevant point is that it is a phase conductor (line conductor in new money) of a single phase circuit. It is not correct to identify it in any other way. Nor have you explained any benefit in doing so.Of course it is.It isn't useful for identification to have a phase conductor in any colour other than that appropriate for a phase conductor.
How can it not be?
No - the other relevant point is that it has a specific function which is worth identifying.Because the only relevant point is that it is a phase conductor (line conductor in new money) of a single phase circuit.
Functional identification is not incorrect.It is not correct to identify it in any other way.
To assist in identifying its function.Nor have you explained any benefit in doing so.
We only have your word for that.The use of red and black, or brown and blue sleeved here would frankly be considered very rough.
And the relevance of what is, or is not, allowed in foreign countries is what, exactly?And in a neighbouring county it is prohibited.
As I recently wrote:Because the only relevant point is that it is a phase conductor (line conductor in new money) of a single phase circuit. It is not correct to identify it in any other way. Nor have you explained any benefit in doing so.
I'm a little surprised that BS7671 does not include requirements for functional identification of conductors in this sort of situation. To merely require that it be identified as a conductor which is, or may sometimes be, connected to phase/line/'live' is not really enough.
