Karcher K4 Pressure Washer
14 Nov 2009
Bristol
I'm thinking of buying one of these. If you've got one you may be able to help me with this. The Ads talk about it being possible to draw water via a bucket. But, will it also connect to an outside tap using a standard Hoselock 'yellow and orange' fitting? Also, what do you think of the product? Any advice would be gratefully received. Thanks.
Yes, no problem.
This is quite a good machine as the motor is water cooled, but do remember it's a diy machine and not designed for continuous duty. Therefore, use it for 10 mins and then rest it for 10, if you get my drift.
Let it pump dry after use, and protect it from frost!
John :)
This one?
I'm guessing, but aren't all PW's connected using these fittings, even if this one has the additional water butt option?
Who are you buying it from?
