Hi, can you help me with an Arming programming question please.
Texecom Premier Elite 24. Wintex software. 2 keyboards.
One area only Area A.
No Area Suites set up.
KB1 in final exit /entry zone.
Door contact final exit /entry programmed as entry/exit 1, ommitable, Auto rearm.
Two PIRs in entry exit zone both programmed as Guard Access. Ommittable. Access. Auto Rearm.
Question:
When Arming at the keyboard near the final exit door I am in the sight of the two PIRs which at the moment of arming are active of course. This causes an arming fault and indication shows the PIRs are preventing Arming. if these PIRs are set to NOT USED then arming is OK.
Sequence is
Do you want to arm-yes
area A in exit mode
Area A arm fail PIR1 PIR2
If by stealth I hide from the PIRs reach and do not exit the SYSTEM arms OK .
It is when I exit that the PIRs pick this movement up and causes alarm fail.
Question:
Sequence is
area A in exit mode
