I'm in the process of purchasing a buy-to-let flat and have just received a copy of an electrical check that was done in June 2013 by the existing owner. It has a couple of C2's, which appear NOT to have been resolved:
No visible cross bonding to bathroom
No visible water bond
A C2 indicates an "Unacceptable Condition".
It appears the existing owner has simply ignored this report, but I plan to be a responsible landlord and I don't believe there is any compromise with health and safety.
The block of flats was built in around 2007, so I'm assuming back then, the building regs didn't insist on cross bonding and have been tightened up. Am I correct in this assumption?
If so, then it would appear that keeping up with the regulations every time they change could be an expensive business, although for these particular issues I don't think they are too difficult to fix.
When performing checks like this, I assume the "current" building regulations are used rather than the regulations at the time of the build.
Appreciate your experience on these types of checks.
