Change orientation of bloorboards
30 Aug 2010
London
I've got the original pine floorboards in my Victorian house. I'd like to keep the original floor but change the orientation by 90 degrees. One option would be to lay 12mm ply on top of the joists and then relay my floorboards on top. The downside is that the floor level would be raised by 12mm and then I would have to re-install the scirting boards . The other option would be to install noggins between the existing joists or install the 12mm ply between the joist so its all flush. What wold you suggest?
Noggins, and plenty of them really! I'd forget about the ply altogether.
John :)
Thanks. How far apart should I space the noggings? Do I need to use joist hangers for them? Is there a better way?
Ideally, keep the noggin spacing the same pitch as the existing joists for maximum support I guess.....
Joist hangers would be ok so long as the noggin tops are level with the joists.
Personally I'd like to notch the noggins in, but there's a fair bit of work involved there.
Is it worth going to all this trouble?
John :)
ok my thoughts
if the floor is well engineered with plenty off redundancy then with noggins it will be fine
if its only just up to spec or a bit under engineered then it may be a bit springy as the load wont be spread over the joists by the flooring but by the noggins which by there nature will allow individual joist to sag till any slack between joist and noggin is taken up
just a thought
John :)
What tool would you use to notch the noggins in?
ok my thoughts
just a thought
How could i check if the joist are engineered with sufficient redundancy?
John :)
Have a look at pictures of halving joints - but there's no need to halve.....only a small amount of notching is needed but a common size is 1/3rd. The noggins can be staggered to get screws in if you want to.
A tenon saw and broad blade chisel are the tools needed.
John :)
you take the timber size say 9x2" the unsupported span [length] off the timbers say 14 ft
and the centres [distance between the centre off a timber to the centre off the next]say 14"
A couple of things:
Why do you want to change the "orientation"?
Are you going to DIY lift the boards? Could be a bigger job than you figured. Could be lots of splintered and split Victorian boards - the old guys used cut nails in flooring.
Stand at the centre of the floor and move your weight up and down in a rhythmic manner and see if the floor begins to flex or creak.
The floorboards go from party wall to party wall. I want them turned 90 degrees to go from from to back of my house. That increases the sense of space
I lifted a few when laying network cable. I managed it all right
I tired that now and there is no noticeable give of creaking
There's a lot of graft involved here but if that's what you want to do then bash on. Plenty of noggins means no sag!
If this is upstairs, be aware that the ceiling may crack due to the hammering or whatever.
John :)
