Hi everyone,
Basically I have an extractor fan (like those used in bathrooms) that has recently died. It should have been an easy thing to replace, but what I found after unscrewing it was that it seems to be stuck on!
I think it is probably stuck on by a combination of decorator's caulk, expanding foam, and most importantly no-more-nails. And the hole is probably a very tight fit for the extractor fan.
I have already tried using decorator's knives to go around the edge all around, and pulling with a couple pairs of pliers. There's absolutely no movement.
I don't want to use a chisel and go crazy because I'm worried about damaging the plaster around. And I can't go to the other side and push the extractor because it's covered by an air brick.
So, any ideas what I can try to remove this extractor fan please?
I've attached a picture.
Thanks.
Thanks.
