We have just bought a fairly big and heavy mirror/cabinet to go in our not yet finished new bathroom (it's 500mm x 700mm and weights 20kg).
However, I'm worried that our skimmed dot and dab plasterboard walls won't be strong enough to support it.
As I haven't actually started the tiling yet, I was wondering if there are any better options than being forced to use these http://www.screwfix.com/p/grip-it-assorted-plasterboard-fixings-32-piece-set/6165j or these http://www.drylinepro.com/ or some other fancy type wall plug?
The only idea that I can think of, is to cut out a letter boxed shaped hole in the plasterboard an inch higher and an inch lower of where I estimate the bracket will end up going, then fill that hole with bonding plaster until it's back level with the plasterboards. I could then use the normal 40mm rawl plugs that came with it. Does this sound like a reasonable idea, or is there a much better way of adding some strength to a dot and dab wall for hanging heavy items?
Here is a picture of the actual bracket against the skimmed dot and dabbed wall (remember though, there will be tiles going over the dot and dab).
The mirror/cabinet was supplied with these normal looking 40mm rawl plugs.
(PS. Whatever I end up doing, as a bit of extra back up, I will definitely be adding a smear of grab adhesive to the back of the bracket so that it's also stuck to the tiles as well as screwed into the tiled wall somehow).
Thanks in advance.
Thanks in advance.
