Hi, please look at the pics. These are the wires into, right hand, and out of a 50a double pole switch. The cable is 6mm running to a 9.5kW shower. Supplied from a rcd and MCB rated at 40a. The cable was screwed tightly into the receiving hole, that is it wouldn't pull out Thoughts please. This is the third of these switches installed in less than a year, normally pawl inside breaks this one just doesn't operate could it be fried. I took one of the other failed switches apart and could see no signs of internal overheating or arcing. Are the switches carp, I asked for an mk replacement last time, nil stock but we can get one for tomorrow, should have waited. Cheers
