- Joined
- 26 Oct 2015
- Messages
- 4
- Reaction score
- 0
- Country
I use this forum a lot for advice but never posted. Hopefully somebody can give me some advice on what I may have done wrong.
I have an Ideal Isar HE24 boiler. Tonight I replaced a radiator, and I replaced the lockshield valve as it was dripping. To do this I had to turn the water off and drain the system, I did this through the pipe up to the radiator if that makes a difference.
When I then fitted the radiator and tightened it up I turned the water back on and heard it going into the radiator, I had no leaks so was happy. The next bit is where I think I may have caused a problem.
The next thing I did was turn the boiler on. I did this before adding water to the system to pressurise it which I think is a mistake, and the boiler now does not work.
When I turn the boiler on I just hear a click but it doesn't fire up, neither does the pump work, nothing happens.
This randomly happened one before without warning and through this forum I found it could be the PCB. I replaced the PCB and it worked. Could what I have done caused the PCB to blow again?
If you need any more info then let me know, any help would be much appreciated.
