Removing GU10s from poorly designed mountings
JBR
9 Jan 2007
Cheshire
A few years ago, I made the mistake of buying some GU10 lamp fittings a bit like these (although these look like the surrounds may unscrew giving access to the lamps, whereas mine do not). I can't find the actual models, probably because no-one is daft enough to buy them any more! The front of the lamp lies flush with the surround and is a devil of a job to get out. I've tried the palm of my hand (licking it first), rubber gloves, a rubber suction cup and even got my wife to have a go! Of six lamps, four eventually came out and the other two I had to break the glass in order to get hold of the lamps with pliers, breaking more glass still in the effort.
I wouldn't touch them again with a bargepole.
Fortunately, the LED lamps I replaced them with are slightly longer, giving an edge I can get hold of.
Have I missed some more effective way of removing these things?
No.
They are just a poor design which are alright when new but after a while being hot they corrode and become 'set in dust' causing too much friction in the connectors.
Might be worth gluing something to the glass with epoxy to get a grip as a last resort.
Some GU10s have 3 or 4 handy ridges in the glass to make it easier.
Stick a piece of gaffer tape on the lamp face to make a handle.
In my experience, the less you push the lamp, then the easier it will turn.
Thanks for the many helpful posts.
I did once use tape on a lamp face to remove it, but I seem to remember the tape ripped!
I could use epoxy resin as suggested, but it would be a hell of a job to get it off the lamp again!
As things are, provided I replace the LEDs like for like, there should be no further problems. As I said, these lamps protrude just enough to allow grasping the edges.
I agree that the fitting is a poor design. When the time comes, and I need replacements, I'll choose more wisely.
Would you not only be doing it on dead lamps which you were going to throw away?
Ah, but I didn't want to throw them away. If they still work, I keep them 'just in case'. It's a trait of the people where I was born and brought up.
With licking, rubber gloves and a suction cup? Top man.
No, she didn't use the rubber gloves!
