K
kai
Why was there an aversion towards earthing lighting circuits before 1966?? - I am just curious.
We survived because .....
Conservative tradesmen. They had been brought up with slip-joint conduit, rubber and cotton insulation.Why was there an aversion towards earthing lighting circuits before 1966?? - I am just curious.
Not an aversion as such, just not considered necessary in many cases. Many people today seem to have the impression that there was no requirement for earths on any lighting prior to 1966, but as the exemption from the 13th edition I posted above shows, that's not so. Earths were still specified where metal switches were used, where fluorescent lighting fixtures were employed, and where other light fittings were mounted so that they could be touched by somebody standing on the floor, could be touched simultaneously with earthed metalwork (e.g. a radiator), and so on.Why was there an aversion towards earthing lighting circuits before 1966?? - I am just curious.
Or because it was during the 13th edition period but used where that edition still required earths, e.g. to fluorescent lighting fixtures or wall lights not mounted out of reach.I'm sure I've seen rubber t+e lighting installations WITH earth present - whether this was because 2 amp sockets were present, or it was before 13th edition, or whatever.
You could - I've got one somewhere. Beautifully chrome plated too.Don't think I've seen a brass bayonet plug, the very thought of one seems dangerous.
For a moment I misread that as "connected to the earth's iron core"!h a brass bayonet plug connected to the iron's earth core
Brass lampholders certainly had exposed-c-ps, as did the switched with screw-on brass covers.I wouldn't call it an aversion. Could it be because there were no exposed-c-ps. ?
Good luck driving that earth rod in.For a moment I misread that as "connected to the earth's iron core"!
Reminds me of that Hilary Swank film.Good luck driving that earth rod in.For a moment I misread that as "connected to the earth's iron core"!
Other versions had a bakelite front cover over a porcelain base, but still with rewireable ceramic fuses with asbestos carrier linings, and double-pole fusing.I remember iron fuse boxes with a handle/switch on the right hand side. the cover would fall open and I'm pretty sure we had fuses on the live and neutral. Would the fuse box have been made by "BILL" ?
