Ive just had an energy efficiency review/certificate done on a building I own, and one of the items noted on the improvements is the replacement of 38mm T12 tubes with 26mm T8 tubes.
However when Ive taken a light down myself to check this, Ive found they are Phillips PL-L, not T12.
Ive done a bit of a google but cant find the anwer, but it looks like a PL-L 4 pin fitting, is just the equivalent of having two seperate T8 tubes.
Has the inspector made a mistake here or can I swap out these PL-L's for T8's and is there as much benefit as the stated "swap T12s for T8's" noted on the assesment?
Many thanks for any help.
