I need some advice as to the brick requirements at the various levels of a dwarf wall for a conservatory. Basically what I would like to know is, do the first courses below ground level have to be engineering bricks? or can I use the facing bricks that I am using for the rest of the wall which are F2 rated. As I understand it the bricks above ground level up to DPC have to be F2 rated, is this correct? My final question, on the internal leaf of the wall, if I use blockwork is there any special requirements below ground level. Thanks in advance.
