worcester bosch heatslave 15/19 new Danfoss programmer
21 Nov 2015
Worcester Bosch heatslave 15/19 on oil
hi guys looking for some help
old timer is playing up and was hoping to replace it with a new one, i got a danfoss dual channel one , wondered if anyone had any advice about wiring it in. no header tank just on demand hot water.
this is where the old one was wired,
Untitled by Giles Bertenshaw, on Flickr
back of the new one
6 into 4? do the off's go else where on the board?
What do you want with a dual channel? It's a combi. A clock to serve only heating needs L,N E if req, a common and SL from stat if fitted.
the guy at the plumbing shop said that was what i needed i asked for a single channel to start with!
It is as simple as it looks. A length of 4 core cable connects as detailed. L and N to live and neutral, Htg on to CH and HW on to DHW.
thanks guys i was over thinking it wondering what to do with the offs etc
its in and working whats the best setting to have the hot water on? as its on demand for hot water so will it just run till the small tank in the boiler fills up then cut off?
I usually recommend all day, or once depending on how your programmer is marked, for the DHW. It will keep the heatstore topped up.
