Pumps knackered.
Is there a test to confirm that gigz ? - its certainly one of the possibilities for sure but what is pumping the hot water around ?
Pumps knackered.
Pumps knackered.
Also, as vulcan says, I know some modern boilers don't have diverter valves, but how the f does a boiler work without a heat exchanger?
The thing that got me though was when you said that the flow pipe was very hot. That would be an indicator of a partial blockage afaik
If it's the model I think it is you don't have a diverter valve or domestic plate heat exchanger. Good you're getting someone out.
