Drilling through brick for cooker extractor
5 Oct 2010
Staffordshire
Hi
I recently had a new kitchen and plan to have the extractor fan vented outside. I have a flyover and want to keep the pipework invisable behind the stainless steel cover. I have bought a 90degree angled flat ducting kit that has a brick sized vent cover.
Im wondering what is the best way to try and ensure I can chisel out a full brick so the cover fits in nicely. My plan was to first drill a hole from the inside out where the middle of the square pipe would go through as a reference point. Im just thinking if this centre point doesnt sit in the middle of a brick (which is 99% likely) what is the best way of doing this?
Is there any flexible piping i can attach from the extractor to the vent cover so there can be a slight bend if needed?
You can't.
Even if you manage to remove a whole brick on the outer leaf, the bricks on the inner leaf will not be in line with it.
The usual method is to use a core drill to cut a 110mm round hole, and use 100mm round ducting. Much quicker and neater than chiselling out whole bricks.
If you don't have a core drill, hire one or find someone to cut the hole for you.
The inner leaf is block work as it is a new build kitchen extension. The reason I wanted a square ducting is that I could keep it compact as possible and hide the pipework.
When I offered up round tubing the bend to get a 90degree angle meant the pipe would just be visbale above the flyover
Thanks mike they look ideal. Im just thinking how I get a low profile 90degree angle off the extractor to start. Then I could use what you have shown to get through the cavity and outside. Is there a piece that converts square to round pipe?
