Me again. With more home electrical madness.
I have a light fitting in a small bedroom with one light switch, nothing more nothing less, but after removing the ceiling rose I found this...
Which, upon removing I've ended up with 4 x three core cables... so I've capped the earth wires off with blocks as the light fitting is double insulted and doesn't need an earth:
But the question is... how do I know what to connect to junction blocks and which one to use to connect to the IKEA wires that go to the light bulb? There's four 'lives' and four 'neutrals' and I need to connect one of each to the IKEA live/neutral wires. I had a similar issue before but with only two three core cables; one was the main live core running through house and the other was the core cable running from the light switch; so they went in a loop.
Any thoughts? Ideas? Many thanks.
