I challenge anyone to solve this problem! I'd be grateful for any input any of you have - I think that it's safe, but it'd be a comfort if somebody could confirm for me.
I've put a new light into an upstairs bedroom - nothing complex involved, simply remove the old fitting and install the new one. Whilst I was at it, I decided to remove the two switches and check the wiring was ok (it's a two-way set-up, with pull cord switch as well as a normal rocker-type switch).
The circuit isn't exactly ideal - it's not a ring, nor even a radial, but simply seems to be a chain circuit. Once I'd removed the light fitting from the bedroom ceiling and disconnected the three sets of twin-and-earth cable coming into the ceiling rose, the bathroom light next door stopped working, and only one of the three twin-and-earth cables coming into the ceiling rose showed live using an electrical screwdriver on the live core. If I connected the mains feed twin-and-earth cable to one of the other twin-and-earth cables (live to live, neutral to neutral and earth to earth) then the bathroom light started working again. If I connected that mains feed twin-and-earth to the third twin-and-earth cable at the rose, then the live core at the pull-switch showed up as live. Therefore, at the ceiling rose, there was a twin-and-earth cable carrying the mains feed, a twin-and-earth cable running to the bathroom light, and a twin-and-earth going to the pull switch. A three-core and earth cable then ran from the pull switch to the wall rocker switch. All straightforward so far?
When I connect the system in the normal way, it works fine. Also, the RCD circuit breaker on the consumer unit definitely works - touching the live core of the mains feed to the neutral core or earth core on the same cable trips the circuit.
BUT - if I connect only the live core from the mains feed to the live core going to the pull switch, but connect no other cores (i.e. the neutral and earth cores going to the pull switch are connected to nothing at either end), then, using an electrical screwdriver, both the neutral and the earth cores going between the ceiling rose and the pull switch test as live using an electrical screwdriver. The same is true if I connect the live core of the mains feed cable to the live core of the cable going to the bathroom - the associated neutral and earth cores both test live using an electrical screwdriver. The same happens if I connect the live core of the mains feed to the live core going to the pull switch, and at the pull switch connect that live core to the live or common core going to the wall rocker switch. All disconnected cores also show live using an electrical screwdriver.
My first reaction was to assume that I'd shorted out the cables somewhere - if they're connected to nothing at either end, then how can making one of the cores live make the other two live as well? However, testing with a multimeter showed the following:
1. The voltage across the live and neutral cores, and the live and earth cores, of the mains feed cable is 235v (as one would expect).
2. If you connect the live core of the mains feed to the live core going to the pull switch or to the bathroom light, but no other cores, then although the electrical screwdriver tests the neutral and earth cores at the pull switch as being live, there is no voltage drop between the neutral and earth cores in the pull switch or bathroom cables and the neutral or earth cores of the mains feed cable. Furthermore, if you connect the neutral and earth cores that show live to the mains feed earth or neutral cores, there is no short, and the RCD does not trip.
3. Testing for continuity, there is definitely no short across the cores of any cable.
4. Although the disconnected neutral and earth cores show live using an electrical screwdriver, if you then connect them to the neutral and earth cores of the mains feed cable, then they no longer show as live with the electrical screwdriver.
All of this has me totally confused. How on earth does an electrical screwdriver test disconnected cables as live? Any advice would be gratefully received!!!
