Earthing Spike
No, because plugs are used for EARTHING, not bonding.
It really is time you learnt the difference, when and why each is required.
OK if the yellow and green wire goes to electrical equipment it is an earth wire and if it goes to non electrical equipment it is a bonding wire. In theroy you can bond without connecting to earth and I suppose there must be a case where class II equipment only is used so the metal is only bonded although I can't think of an example.
In theroy if the earth rods are 0.05 ohm then even if the neutral is lost on a 100A supply the earth will not rise to over a 50 volt point. However the DNO need only have a 21 ohm earth so it would be pointless to have a homes earth better than the DNO earth and with both at 21 ohm then 1.2 amp is the maximum current at which you could expect a fuse to protect. Or 2.4 amp if the home got zero ohms. Neither are practical.
However I would think you could use something like the old ELCB-v if you wanted to disconnect the supply should the supply earth become 50 volt away from the earth electrode, but it would need to be installed in every house to ensure the DNO supply did not have a earth to real earth voltage over 50 volt. To introduce a system like that because of the few times the DNO lost the earth neutral would be like insisting on metal consumer units because some were incorrectly installed and went on fire.
I really don't understand the fuss which is made by some people these days if somebody talks about earthing, say, a metal bathtub, and gets told "It's not earthing, it's bonding."
Yes, you can bond two things together without earth being involved in any way. But if you bond something to an earth connection, then you've earthed it. Even the Wiring Regs. used to talk about earthing tubs, pipework, etc.
That's because it is bonding; not earthing.
You physically can but you should not and it will achieve nothing.
If they are not already earthed in any way then they will not require bonding.
Yes, but you have bonded it to equalise the potential difference; not so that an OPD will operate.
That is the reason for the two terms; so we know what is meant.
Times and terms change.
You are connecting it to earth. How is that not earthing?
Not so. There are plenty of instances in radio-frequency work in which you might want to bond two things together without them being earthed,
But if something live were to contact the item which has been bonded (to earth), the protective device would operate anyway.
The laws of physics don't though.
The purpose is to equalise potential. That is bonding. Simples.
I am talking about electrical installations.
That is true but not the reason for it.
...but what we call them does.
I'm a bit lost here. When people like Bernard want an (otherwise 'floating') metal bath to be 'connected' to the CPC system, the reason given is usually that it facilitates operation of a protective device if/when some drops the infamous hairdryer into a bath full of water and persons.
That's surely earthing, not bonding?
I don't think you are.
Well, yes. Would it do that?
I was taking the question to mean (as it was) when people were talking about actual required bonding and wrongly calling it earthing.
Wrongly applied bonding (when NOT required) is indeed earthing.
When people like Bernard want an (otherwise 'floating') metal bath to be 'connected' to the CPC system, the reason given is usually that it facilitates operation of a protective device if/when some drops the infamous hairdryer into a bath full of water and persons. That's surely earthing, not bonding?
Would it do what - facilitate operation of a protective device? It would certain trip an RCD, if there were one in the supply to the hairdryer, but it probably wouldn't cause an OPD to operate (anless some life part of dryer came in contact with bath, rather than just the water) - does that qualify as 'earthing' in your book?
That's not how I interpreted PBC's comment/question to which you were responding. Apart from anything else, neither bonding nor earthing of a 'floating' bath is ever required.
It is, which is why it should not be done - the bath is not an exposed-conductive-part.
Ok. undoubtedly he will tell us.
However:
If you are correct, then they would not be told "It's not earthing, it's bonding", would they?
The problem would then be people who are referring to earthing as bonding by mistake - not generally the case.
Anyway, when he wakes up, he will probably think of something to continue your hyper-hair-splitting debates of recent.
I do get the impression he is a bit of a wind-up merchant.
